Hey guys, anybody got this working? I have successfully installed the Revit Central Server and followed the step “Enable Revit Server Access with Revit Application”, but I never seen any indication in my Revit application that it is server aware.
I’ve submitted a support ticket, but I was wondering if anybody else has this working.
TexasJetter
see attached
i just installed the client part of it i don't have server 2008 so i can't use it
DarrenP
its also supposed to be here:
DarrenP
I wasn't seeing that part, but I finally discovered the "Connect to Revit Server" under the Collaborate tab
After connecting to the Revit server the Server icon shows up in the Open/Save short cuts.
So, it appears to be functioning now. The quesion is will it work
i would like to know how well it works
DarrenP
For now I can confirm little more than that it does work. A user in our central office can load up a Revit project from the Central Revit Server, while another user in remote office loads the same project from the "Local Revit Server". Once a save to central occurs it is then propagated to the other office. Although they did have a problem when they both tried to save to central at the same time
I do see that there will be some issues to work around. For instance Revit Server only does .rvt files (as far as I can tell), if we have any linked CAD files (risers, one lines, etc) they will need to be in both locations. Coming up with a system to sync the supporting non-Revit files may be a challenge. Ok, I can hear the purists now - just do everything in Revit. But the non .rvt statement also applies to the keyed note file. Wonder when Revit will have integrated Keyed notes.....
As far as linked dwg's are concerned, we have found that offices that have Riverbed Steelhead WAN accelerators do a good job of cahcing linked dwg's on models that are on Revit Server. This has eliminated our need for copying .dwg's around on the network. Obviously they don't just give those things away $$$ but it's worth mentioning.
