Revit MEP
New Member
cfields
Message 1 of 5 (510 Views)
Revit Server - Cannot Lock Server
510 Views, 4 Replies
12-06-2011 07:08 AM
I'm running revit server, and revit mep versions 2012.  I want to use Revit Server 2012 Update Release 1.
Following instruction #3 in the readme file, I login to the server admin interface.  Click the central server at the top of the list, and press lock.
About a minute goes by, and I recieve "Cannot Lock Sever.  This operation cannot be completed beacuse the server could not be locked.  Refresh the data and try again."
I've verified that all users on the network are out of revit entirely.  How do I diagnoise this so I can get the update installed?
Product Support
fernanda.firman
Message 2 of 5 (476 Views)
Re: Revit Server - Cannot Lock Server
12-13-2011 09:50 AM in reply to: cfields
I understand you want to install the Revit Server UR1 but have not being able to. Please check out the step by step in our blog:
http://revitclinic.typepad.com/my_weblog/2011/07/revit-server-2012-update-release-1.html
Hope that helps.
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
New Member
cfields
Message 3 of 5 (454 Views)
12-15-2011 06:16 AM in reply to: fernanda.firman
Fernanda, In this case the error happens at step #2.  All users are logged out of revit on the network.  I wish the autodesk server admin error message was more descriptive - this is a screencapture:
http://i44.tinypic.com/16022a8.jpg
Is there a process of sending log files to Autodesk for resolution of this problem?
Active Member
tgates
Message 4 of 5 (432 Views)
12-19-2011 09:58 AM in reply to: cfields
You might need to shut down all the local revit servers before you can lock the central revit server down. I had to do this before I could lock down the entire server.
Product Support
fernanda.firman
Message 5 of 5 (391 Views)
01-12-2012 01:40 PM in reply to: cfields
If you are still having trouble please try the following:
1. Do a search for*.lock in the projects directory and look for all non-zero files. Please confirm that these  locks do not correspond to operations in flight - i.e., they are orphaned and clear them out. Once all orphaned locks are cleared, attempt to apply the admin level lock again.
2. Make sure to install the latest RS UR, which contains an enhacement to display orphaned model level locks in admin.
Hope it works.
Revit Clinic
