We have installed Revit Server 2013 and used a remote network storage location. I now have to move that location. How do you change the storage location pointers in Revit Server 2013? There are not currently any models in Server. So all i have to do is move the storage.
Solved by Lance.Coffey. Go to Solution.
The option to specify the project folder location is available when installing Revit Server. I have not found an option to change this location other than uninstalling, and then reinstalling Revit Server.
That is what i ended up doing. Would be nice to have the ability to relocate this in the future. I guess that i need to put this on a wishlist.
Has been been any changes to this? Do you still have to uninstall/reinstall Revit Server? What if there are projects in this location that need to be in a different location?
I haven't seen any changes to this behavior.
When you say that a project may need to be in a different location, if you mean a different physical location (like a different site), you can transfer projects between Host servers using Revit Server Administrator.
