Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Revit Research
19 REPLIES 19
Message 1 of 20
Femcadder
490 Views, 19 Replies
Revit Research
We are drafting with stone and chisel here. Currently using Softdesk 8. We only will be in 2D and are HVAC, Plumbing, Mechanical, Electrical (as far as controls are concerned).
We want to upgrade to the latest and greatest (STILL 2D) ADesk. Is that going to be Revit MEP?
Is this where I would post and read about MEP?
THANKS
Fem
19 REPLIES 19
Message 2 of 20
jayspot
in reply to: Femcadder
Revit is 3D so it wouldn't do you much good if you only draw 2D objects. I'd say the latest version of AutoCAD would be your best bet.
Message 3 of 20
Femcadder
I forgot to mention what Softdesk is. It is an add on that has all the piping, fittings, equip, ducts, blah blah blah, already in it and quick. (Softdesk is no longer)
Would it make sense to stay in ACAD and get an add on? If so, help, which one?
THANKS
Fem
Message 4 of 20
I would just stay with what you have. How many more years do you have until
you retire? Any other software will require thought, effort and learning
something new. It does not look like you want to invest in any of that.
Come to think of it, just whip out that drafting table. It would probably
work the best for you. 😉
wrote in message news:5525099@discussion.autodesk.com...
one?
THANKS
Fem
Message 5 of 20
Femcadder
You are killing me! *smirk*
I come from 3D in manufacturing/mechanical engineering. (I have worked on stuff that have gone into space!)
I am now in MEP. Seems all the Architects we work with are also in 2D.
We really need to look into something, just wondering what that will be. ACAD LT 08 and an add on?
Fem
PS I have a good 30 plus years until retirement.... 😜
Message 6 of 20
jayspot
I guess the real question is what do you want the software to do? What type of "add on" are you talking about? Maybe explain what a typical drawing would consist of so we have a better idea about what you do.
Message 7 of 20
Femcadder
Ah, sorry 'bout that, this is new to me.
We put in HVAC ducts and equip, plumbing for both HVAC and well, plumbing. The electric for the equipment, so basically the controls. And also sprinkler systems.
We xref in the Architects 2D drawnings (different companies, different software).
Sometimes is is just schematics, and 1 line stuff, sometimes it is more detailed but still just 2 line stuff. We are usually just looking down into a floorplan, but sometimes will look into a room from the side.
Pretty basic, but it is nice because now we have R14 with an add in called Softdesk that has library blocks that will come right in. It is all pretty quick.
The purpose of upgrading isn't because what we have now doesn't work, it does and does it well. We are looking to upgrade because it is becomeing more and more difficult to find support and also to convert from the architech's stuff.
We really like the thought of ACAD LT 2008, but can't run it plain. We are looking for something to help, with out going overboard. Any thoughts? Looking at Mech Q maybe?
*sigh*
THANKS for the input!
Fem
Message 8 of 20
As a Facility Manager, I have to note...
all of our MEP contractors are using full AutoCAD (04-07). Our
architects are using ADT (autocad architecture... their custom objects
are the biggest pain in my tushie).
They just take their block library and make a tool palette out of us and
drag and drop the same symbols/blocks they've been using since r14.
Melanie Perry
***not all who wander are lost***
http://mistressofthedorkness.blogspot.com
> *sigh*
> Fem
Message 9 of 20
You need to make sure that your Architect is using Revit Building for doing their Architectural work. Then you need to do your MEP Work in Revit Systems.
Simply;
Architect work in BIM = Revit Building
MEP Work in BIM = Revit Systems
Message 10 of 20
unjust
from the sounds of things you want to be running ACAD LT probably 2007 although there are some AEC object issues with prior versions.
from there you could use any of the mfg provided blocks for details, and run with line drawings.
depending on the # of seats you have one seat of full ACAD will give you access to the AECTOACAD command to remove the AEC issues and give you more power to tidy up incoming xrefs.
if you want to go 3D revit is the way to go, however it still has some issues in the MEP areas, and Revit is not as widely used by architects (yet) autodesk building systems may be something else to look into.
Message 11 of 20
AutoCAD MEP 2008 is a direct descendant of the Softdesk MEP package. So
since you are already familiar with the Softdesk product this would probably
be the closest thing to what you are using right now. Please keep in mind
AutoCAD MEP does create 3d objects for ducts etc... So this will be a change
to the way you are currently working. It is also quite a few releases of
software since the last softdesk product. One nice thing about it is that
is based on Vanilla AutoCAD so you can ease your self into using the new 3d
features and simply draw in 2d. What ever package you choose to go with, I
would strongly encourage you to invest in some training in the new package.
Jeff Hanson
Autodesk - AEC Technical Publications
Manchester, NH
_______________________________________
one?
THANKS
Fem
Message 12 of 20
LT would be a huge mistake. You cannot customize LT with "add-ons". And
don't let anyone tell you about "enablers" for LT customization. There are
still significant issues with such enablers that will limit your abilities.
R. Robert Bell
wrote in message news:5525730@discussion.autodesk.com...
sprinkler systems.
software).
quick.
architech's stuff.
*sigh*
Fem
Message 13 of 20
LT does *not* have sufficient customization ability, IMHO, to support an MEP
firm.
R. Robert Bell
wrote in message news:5525890@discussion.autodesk.com...
with line drawings.
Message 14 of 20
unjust
really? 80% of my office uses it with some pretty heavy customization and automated block tweaking.
AutoLISP is still supported last i'd heard and is pretty customizable.
Message 15 of 20
LT has never supported Lisp.
Message 16 of 20
unjust
sorry, you're right, it's been one of those weeks.
i meant command line customization with toolbars/buttons. yes, it's no lisp, but it's still pretty powerful.
for practical purposes if theyr'e doing 2d drafting, with dynamic blocks in LT they've probably got all they need. granted it's not as automated as the dedicated MEP stuff, but from what the needs seem to be i'm not seeing the cost benefit of building systems or revit systemss/MEP
Message 17 of 20
Okay... glad I hadn't mis-read anything. 🙂
Oh, in that case I understand... as I mentioned above, most of my MEP
contractors could likely get by with LT (as you say, as long as there is
at least one full seat to help deal with architects backgrounds, etc).
cheers.
Melanie Perry
Message 18 of 20
benrei
We use Design Master for our HVAC and electrical work (http://www.designmaster.biz). It requires full AutoCAD--AutoCAD LT won't work. You don't have to use the 3D in the HVAC part if you don't want to.
Message 19 of 20
mcoffey
Being someone who is VERY familiar with Softdesk, I used versions 7 and 8 and used it until the company I used to work for upgraded to ABS 2005. So, I'm also pretty familiar with the jump from R14 S8 to ABS/MEP. As has been stated here AutoCAD MEP is probably your best bet. It works very similarly to Softdesk in that you don't have to draw single lines and offset for double line ducts and pipes. You also don't have to go back to the symbol library and insert things like elbows and fittings. MEP does that for you on the fly. It is a 3D based software that draws at elevation but that can just be ignored since you only want 2D drawings. From a plan view you'll never be able to tell if the ducts and pipes are at an elevation or not.
Matt
Message 20 of 20
Femcadder
Very cool. Thanks for the info.
We have had contact with our local distributor. *grin*
We will evaluate AutoCAD MEP 08.
THANKS
