I'm sure this is very similar to the Missing Section Tag Topic.... I'm having the same issues along with Missing Elevation Views, or Elevation Directions, (Please refer to screen shots). This has happened to me before, causing me to only provide screen shots of the project instead of the full blown file for a class project, (thank GOD it was only for a test).
What exactly is happening, or causing this problem? I don't want to be put in a position again where I need to provide full sets of drawings and can not justify, or show where my Section Cut Tags, Elevations , or Annotation/Room Tag Information are missing in the plan views
Solved by CoreyDaun. Go to Solution.
Solved by AnmarieJames8335. Go to Solution.
Solved by julianjameson8403. Go to Solution.
The View in which the Elevations and Sections are missing is set to the Electrical Discipline. I imagine that the Elevation and Section Views are set to the Mechanical Discipline, and thus, will not show on an Electrical Plan. If you set the Section Views to Coordination Discipline, they will show up in all Views, though this will affect their visibility settings.
Part of the problem also is understanding Revit workflows and the effects of parametric relationships built into Revit.
You should aim to be quite fastidious and quite regimented when using the software to avoid these seemingly catastrophic but simple problems.
For example - you have played with the settings of the mechanical view to display electrical components and inadvertantly given yourself a lot of problems and grief from the bosses. Try duplicating the view, renaming and then changing the settings so you have two entirely different views performing separate tasks. Then you can decide whether you want an electrical section or a Coordinated section - as suggested by CADastrophe.
For more (limited) information on this refer to the Wiki :-
To CADastrophe & JulianJameseson8403,
Thanks for your response and sorry for not getting back to the both of you any sooner.
Both of your responses seem valid and I will research them both since the work I'm doing is a mixture of all 3 disciplines (Mech. Elect.& Plumbing), meaning for one of my systems I will add or drawing something that involves them all. That being said with out me knowing, the families are probably in the right spots, or disciplines and eventhough I may be on the ductwork (mechanical view) I probably can not see the conduit wiring for my damper and the actuator or the piping because those items are in the electrical and plumbing views.
I will let you know if these are valid answers, or responses.
Thanks again,
Milt (a.k.a. Drafter1981)
To clarify, any elements in the Model Categories are available to "be seen" in any view, it's just a matter of adjusting visibility settings. Having said that, there are several of these settings (the Properties palette has some but not all), so it makes sense to set up each view for a specific discipline.
It's also helpful to create a second view for some disciplines...2 1st floor HVAC plans for example. One view to show everything how you want it displayed on a sheet, another to use for creating the content (which may have elements turned on for reference, or shown a different detail level or visual style). This way, you're ready to plot at a moment's notice, without having to go back and forth with settings like if you used just one view for both working and printing.
You mentioned "Conduit Wiring". I'm unsure of exactly what elements your referring to, but note that Conduit is a Model Element that will appear in any view according to View settings, as explain by AnmarieJames8335. But as for actual Wiring, while it is listed under Model Categories, they behave and appear as Annotations, meaning that the Wires must be created in (or copied to) each View you want them to appear in as they will only display in the View in which they were created (and Dependent Views).
To CADastrophe, JulianJameseson8403, & AnmarieJames8335,
Again, thank you all for your responses. It seems as if a little of all of your suggestions had to be used. So far the only thing NOT showing up in the views that I need to see are my heating and cooling valves which now obviously need to be on the plumbing plan, and needs to be tweaked as far as visibility, (I have all 3 disciplines shown on another test file).
Refer to my "Test-2" screen shots that shows all 3 disciplines.
