Revit MEP2013 crashes when switching between views with error message (A serious error has occured. It is strongly recommended that you save your work in a new file before continuing.).I saved the file as a new revovery file. Whe I open the recovery file I got the same error.My Revit service pack installation is up to date.
Please Help.
I used to get that message alot on my laptop. If you are using a laptop, you might want to turn off your Hardware Acceleration. Application Menu>Options> uncheck box. I hope that does it for you.
