Revit MEP Forum
Revit MEP HVA Zone Colour Schemes
1 REPLY 1
352 Views, 1 Reply
Help!
I am fairly new to revit , but learning it quite quickly. However I have hit a problem. What i am trying to do is to create a zone made up of around 22 spaces then apply a colour scheme to it. the spaces add to the zone ok but when i apply a color scheme to the view some of the spaces don't show coloured they stay the same default green colour of the space, when I edit the zone and remove these spaces and add other ones, different spaces then become un coloured. The colour scheme is simply based upon the name of the zone so every space within that particular zone should be the same colour but its not happening. I could maybe under stand it if this was happening to the same space all the time but its different spaces. Maybe im doing something wrong I dont' know but all help and advice would be greatly recieved
1 REPLY 1
CoreyDaun
Hello, and welcome to the Discussion Groups!
Can you attach the Project file here? You can create a sample file by opening your Project with "Detach from Central" (if it's Workshare Enabled) and by removing unnecessary elements and purging. If you cannot get the file small enough to post here, then send me a Private Message and I will give you my email address if you would like me to take a look.
