OK - Can we revisit and refresh an update from Autodesk on this. While I understand Martin's answer - I would like to circle back to Matt's original questions regarding how this should actually work.
My scenario is that we are a full service AE, with all disciplines attempting to work in Revit. Per what has been described above - we have generated a "Standard" library of fixtures w/ plumbing connectors that has been coordinated with Arch/Plbg disciplines, and we include them in our Arch template. This resolves the positioning, etc. When we copy / monitor - but not the other issues identified. So - I would like some clarification on the questions below;
Thanks for any help and direction!
Dean
Martin,
I understand your family insertion point and rotation comment completely. However, I came across the same issue as Matt Dillon. I did a test Electrical project with a linked Arch model containing a single 2x4 120V troffer. I monitored the Levels and batch copied out the original parabolic troffer. No problemo. My issue is when I move the light in the link, Coordination Review Manage sees it and gives me the coordination warning. So, I manually move the copy to match the link. I would expect the issue to be reconciled but, I too receive a secondary coordination warning. Why?
If you go to Steve Stafford's RevitOpEd post on "Dept of Quirky - Copy Monitor Fixtures" he addresses the rotational issue as being ignored. When he moves the copied light to match the relocated linked light, he doesn't receive a secondary warning and Coordination Review Manager is clear of any warnings.
Am I missing something too?
I just got into this issue myself (MEP Firm), trying to work out with one of our clients (Architect) the best way to handle ceilings, ceiling fixtures, changes to same, etc.
I was totally disappointed to find that Batch Copy is nice for a sales pitch, but not not as helpful as it could be.
Most of the lighting manufacturers are creating their fixtures with the insertion point at the center of the fixture. It may be easier to have them modify their generic fixtures to match what the real world is doing. Or, the MEP firm could provide the architect with a modified set of generic fixtures. I almost like that idea. It beats having to fix all the manufacturer's models.
