Revit MEP 2012 won't allow me to add devices to or remove devices from an electrical circuit. It worked for me on Revit MEP 2011. Is there a setting for this?
Also, there is not Convert to Wire panel when editing a circuit, nor a Convert to Wire icon, as shown in some of the Revit MEP books.
When you select an electrical device that currently belongs to a circuit, there is a contextual tab available for Electrical Circuits that does not automatically become selected. You must go to this tab and then to Edit Circuit.
To generate wiring for a circuit, you must hover over an element of that circuit and press tab. Select the circuit and you will see a couple of icons appear for generating the wiring:
Existing wire must be deleted and re-created to change it's type. To easily delete the existing wire, highlight the wire, hit Tab to select all the elements of the circuit, and use the filter to select only wire elements and delete them.
I have Revit 2013. I want the wiring of the elctrical circuit to be shown. There is not "Convert to Wire" icon or option. I can make appear the wiring using the Tab and pointing to the device, but the wiring does not show permanently after all. Please advise what to do.
Hello, and welcome to the Discussion Groups!
It sounds like you might not be selecting the Electrical Circuit, but just pressing Tab and "highlighting" it. After you press Tab and the dashed image of the Wiring appears, click to select the Electrical Circuit and then the "Create Wire" icons should appear as per the image in my previous post.
As CADastrophe points out, the "Convert to Wire" icons do not appear until you select a circuit. When you hover over a circuit element and press Tab, the circuit will be displayed as a dashed rectangle enclosing the circuit elements, but it is not selected until you left click. When you select the circuit, Revit will display dashed wires between the circuit elements, which are the wires that Revit proposes to draw. When you have selected the circuit, the Convert to Wire icons will appear in the ribbon, and somewhere in the the graphics window. Click the icon, and Revit will draw the wires. You can also draw wires with the Wire button on the Systems tab of the ribbon.
