After installing Revit MEP and running it without activation code everything works fine. Once Revit MEP is activated with acivation code an error occurs at the splash screen(Please see attached image of screenshot).
I cannot get past this point and it is terribly frustrating. Help will be much appreciated.
You can check the following article on the Revit Clinic:
