Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
REVIT MEP 2014 TEMPLATES AND FAMILIES
24 REPLIES 24
Message 1 of 25
14776 Views, 24 Replies
HI every body ..
iam anew user for revit mep 2014  but i takes my way step by step with it till i found
a problem with templates & families
from where can i set an electrical template
and how to deal with families ??
iam sorry for my bad english & for my stupid question
24 REPLIES 24
Message 2 of 25
CoreyDaun
Hello, and welcome to the Discussion Groups!
I would suggest starting on your first Project using the default Electrical Template. Load in all Families* and make all changes as needed to the Project, including setting up View Templates and the like. Once the Project is complete, you can create your Project Template based off of this File for use with other Project. It will l take a good deal of use before your Project Template is in good enough condition, and you will likely never be done making modifications to it.
*You can find Families in a few places, such as Revit City, directly from a manufactuerer's website, or on Autodesk Seek.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 25
selders
in reply to: CoreyDaun
I am working with REVIT MEP 2014 and I do not have a default Electrical Template. I do have Construction, Architectural, Structural and Mechanical. How can I download the Electrical Template?
Message 4 of 25
CoreyDaun
in reply to: selders
If you go to the Application Menu (the big 'R') New Project and click "Browse...", you don't see it? They should have been included in the initial install, but if not, I have attached the default electrical Templates that I have for both Imperial and Metric (in .zip files since this forum disallows .rte files). They should be placed under the folder below.
C:\ProgramData\Autodesk\RVT 2014\Templates\US Imperial
*"RVT 2014" is for the full version, it may be different for you.
Message 5 of 25
Can any body help to get me template for Arch & Mechanical AutoCAD Revit 2014
Message 6 of 25
Can u send me the templates files? I need Mechanical template but i couldn't find out.
Message 7 of 25
salim.hamieh
heres the mechanical templates
Message 8 of 25
salim.hamieh
Message 9 of 25
samuel2VR65
Hiall,
Apolgies for bringing this thread back to life, but it seemed the most appropriate thread to post on.
I am in the process of creating a Project template for the company i am working for and i have pretty much finished the first run through including, views - sheets - filters - view templates - annotation settings - to name a few (i have no doubts about the fact i will need to modify this later on). my query is this:
I have added levels to the project template - obviously when i bring in an architectural model and copy monitor etc. these architectural models will move as and when the architect alters building height, floor heights and whatever else. How can i get the levels that i have added into the template to move with the changes that the architect does to theirs.
I have spoken to a number of specialist companies and have been made aware that this is possible, but i need to go on a training course to learn how to do this, it is also mentioned on the AutoDesk Knowledge webpage under the project templates section.
Any help would be appreciated
Thank You
Message 10 of 25
m.voss.alvine
in reply to: samuel2VR65
we typically just delete the levels that were part of the template after we copy/monitor the linked levels.  they are there a placeholders.  we use the starter project method so that we can also setup all of our standard worksets and links.
Revit MEP 2015 Certified Professional
Revit Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional
remember to 'accept as solution' if this helped
Message 11 of 25
samuel2VR65
in reply to: m.voss.alvine
Thanks for the reply Mitchell,
I thought deleting the levels that were put into the template would delete the views that have been set up, as each level is associated with a particular view
Message 12 of 25
m.voss.alvine
yes, that is correct.  are you using view templates in your views?
Message 13 of 25
samuel2VR65
I am using view templates yes,
so i have set up views based upon the levels i created and applied view templates to these depending on service types. The copy/monitor aspect is the only area that is troubling me
Sam
Message 14 of 25
CoreyDaun
Hello, and welcome to the forums!
When you're linking in the Revit model, Instead of using Copy/Monitor with the linked model, manually move your Levels to match those of the linked model and just use the Monitor to establish a relationship. If the linked model has additional Levels, then use Copy/Monitor for those.
Message 15 of 25
samuel2VR65
Thanks Corey,
That sounds like a winner!
i will give this a try out today, my main concern would be if the architect has to change their levels for whatever reason, and then i have to manually move up all the M&E services
Sam
Message 16 of 25
samuel2VR65
So, i gave the above a try as suggested, and when i loaded in a new model that has different levels to the previous (provided by the architect) i was notified that the instance required co-ordination, which is miles more information that it's given me before. Happy that i am a step closer!
However, the levels that i inserted into the project template stayed at the same level as the architects previous model.
Is there a way to get my levels to move up with the architects levels should they change in this way? I've attached a screen shot of the notification i received
Sam
Message 17 of 25
CoreyDaun
Under the Coordination Review dialog (Collaborate tab Coordination Review Select Link), you'll be presented with possible actions to resolve the conflict, one of which should be to move your Levels to match their associated Level in the linked model. This should be identical between those Levels that are created with 'Copy/Monitor' and those existing Levels that are associated with 'Monitor'.
Message 18 of 25
samuel2VR65
Corey,
Thanks, that has worked a treat!
I have tried to select this as a solution, apparently i don't have the privileges to do so.
But for all reading, If you are looking for the solution, this is it!
Thanks again
Sam
Message 19 of 25
I am also having a very hard time finding a template that includes mechanical and plumbing. Also a template of just an open building so I can try to add and design a mechanical system into it. I am very fluent in autocad and solidworks but I am really struggling with this program. Solidworks has tutorials that you can work through and so far as I have seen Autodesk rebut has none of the above. Thanks to anyone that can help I would truly appreciate it.
Message 20 of 25
Dear All of my friends,
I'm new member of this group.
Now I have a little problem.
That's I have no template for revit mep 2014.
So please kindly help me for this template.
Thank you very much.
Best Regards,
Nay Lynn Aung
