Hi All, fairly new Revit user, only been using the software for about 3 months now. So I like to have my properties dialog box on the left side of the screen, it is always on because of how frequently I use it. When i open one project, everything is fine. When i open a second project, the properties box goes into the funky error state attached. Can anyone help? I have no idea what is causing this or how to fix it and my IT is stumped. Thanks all!
Solved by L.Maas. Go to Solution.
Sometimes this is caused Revit became corrupted. Often after a crash or sudden shutdown.
This can often be solved by renaming a key in the window registry
RENAME:
Autodesk Revit MEP 2014
IN:
HKEY_CURRENT_USER\Software\Autodesk\Revit\
Louis
Please mention Revit version, especially when uploading Revit files.
