Revit MEP
Member
RodriguezMEP
Message 1 of 6 (1,982 Views)
Revit MEP 2013 - Line Styles Weights
1982 Views, 5 Replies
09-05-2012 04:33 PM
I'm not having a problem with my Revit program but i do have a concern on how my piping is shown when i go to vew mode "fine", now that it is 3D the piping is showing up to BOLD, which i really dont like how that looks, so i need direction in how to change the BOLDNESS to a thinner line. I was told it has to do with Line styles but I dont know where i can do this adjustment. Please Help.
Key stroke should be OS for object styles or under manage/settings/object styles
Active Contributor
tjbeecher
Message 2 of 6 (1,965 Views)
Re: Revit MEP 2013 - Line Styles Weights
09-06-2012 07:03 AM in reply to: RodriguezMEP
Under manage additional setting line weights in there you can see the line weight for each setting.  you can then go to the object styles and play with the projection number to make it thinner.
Member
RodriguezMEP
Message 3 of 6 (1,953 Views)
09-06-2012 10:12 AM in reply to: tjbeecher
how do i get to the additional setting window?
abulla
Message 4 of 6 (1,949 Views)
09-06-2012 10:26 AM in reply to: RodriguezMEP
Of if you're just using the 3d view for modeling, just use the Thin Lines command (TL keystroke) on the quick access toolbar at the top.
Active Contributor
tjbeecher
Message 5 of 6 (1,947 Views)
09-06-2012 10:32 AM in reply to: RodriguezMEP
Member
RodriguezMEP
Message 6 of 6 (1,944 Views)
09-06-2012 11:06 AM in reply to: tjbeecher
This worked.. Perfect.
Thanks. :smileywink:
