Revit MEP Forum
Revit MEP 2013 - Line Styles Weights
5 REPLIES 5
RodriguezMEP
3061 Views, 5 Replies
I'm not having a problem with my Revit program but i do have a concern on how my piping is shown when i go to vew mode "fine", now that it is 3D the piping is showing up to BOLD, which i really dont like how that looks, so i need direction in how to change the BOLDNESS to a thinner line. I was told it has to do with Line styles but I dont know where i can do this adjustment. Please Help.
5 REPLIES 5
tjbeecher
in reply to: RodriguezMEP
Under manage additional setting line weights in there you can see the line weight for each setting.  you can then go to the object styles and play with the projection number to make it thinner.
RodriguezMEP
in reply to: tjbeecher
how do i get to the additional setting window?
abulla
Of if you're just using the 3d view for modeling, just use the Thin Lines command (TL keystroke) on the quick access toolbar at the top.
tjbeecher
Key stroke should be OS for object styles or under manage/settings/object styles
RodriguezMEP
This worked.. Perfect.
Thanks. Smiley Wink
