Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Revit MEP 2013 DWF Markup Error
2 REPLIES 2
JackTrex
398 Views, 2 Replies
I am having a problem with the 2013 release. When I turn the dwf markups to DONE then print the sheets with the corrected markups it gives me this error when I open the dwf.
The markup data on this page contains errors. You will not be able to edit the markups or add new markups to this section.
This looks like we will have to change our hole workflow process.
2 REPLIES 2
JackTrex
in reply to: JackTrex
I created the original post and an Autodesk rep contacted me and sent me an ftp site to download the files. I have had problems with the ftp site and I would like the rep to contact me again as I can not email him because the message keeps bouncing back because it is looking for the CaseNO reference. I have added the CaseNo and still nothing.
If the original person from Autodesk Support could contact me again and set something up where we can talk back and forth so we can figure this issue out that would be great.
Lance.Coffey
After working on this with JackTrex outside of this thread, I wanted to post the solution we found, so that if others run into this issue, they will know what to do.
The solution we found was to install Update 2 for Revit.
Lance Coffey
Technical Support Specialist
