Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Revit MEP 2012 Duct Fittings not moving with Level
2 REPLIES 2
aturner77
745 Views, 2 Replies
Revit MEP 2012 Duct Fittings not moving with Level. The Ducts move but the Duct Fittings will not.
2 REPLIES 2
CoreyDaun
in reply to: aturner77
Have you tried searching through the forum for this issue? I know it has come up in the past.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
sergiolj
That problem makes no sense!
When I change the level pipes are updated but fittings no? The fittings aren't conected with pipes? There is any way to maintain both conected?
Someone find the solution?
