Revit MEP
Valued Contributor
aturner77
Message 1 of 3 (514 Views)
Revit MEP 2012 Duct Fittings not moving with Level
514 Views, 2 Replies
01-26-2012 01:19 PM
Revit MEP 2012 Duct Fittings not moving with Level. The Ducts move but the Duct Fittings will not.
Have you tried searching through the forum for this issue? I know it has come up in the past.
CADastrophe
Message 2 of 3 (484 Views)
Re: Revit MEP 2012 Duct Fittings not moving with Level
01-31-2012 05:33 AM in reply to: aturner77
New Member
sergiolj
Message 3 of 3 (267 Views)
03-15-2013 07:19 AM in reply to: aturner77
That problem makes no sense!
When I change the level pipes are updated but fittings no? The fittings aren't conected with pipes? There is any way to maintain both conected?
Someone find the solution?
