Revit MEP Forum
Revit MEP 2012 Duct Fittings not moving with Level
2 REPLIES 2
750 Views, 2 Replies
Revit MEP 2012 Duct Fittings not moving with Level. The Ducts move but the Duct Fittings will not.
2 REPLIES 2
CoreyDaun
Have you tried searching through the forum for this issue? I know it has come up in the past.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
That problem makes no sense!
When I change the level pipes are updated but fittings no? The fittings aren't conected with pipes? There is any way to maintain both conected?
Someone find the solution?
