When I tag more than one element in a view, my keynote values disappear on my sheet where the keynote legend is placed. Where as the keynote value shows up if I only have one element tagged. Any thoughts?
Well.
You should be filtering by sheet and your numbering method should be by sheet.
Are you using any other filtering or sorting?
I am having the same issue. I am filtering the keynotes by sheet. This happens whenever their are two views that overlap in dependent views. I will populate the first 1-3 numbers but after that they are blank. If the view box is moved so there is only one view controlling that keynote then the number comes in.
Anyone run into this or have thought about how to fix it?
I have seen this before on 2 different projects.
Did you upgrade the project from a previous version?
When this happened to me there was nothing I could do. I had to place "dummy text" (not to be confused with dummy Revit) in the keyed note bubble.
I couldn't get it to work for the life of me.
Both projects this happened on, were upgraded from a previous version and they were on dependent views.
If you figure it out, please post the solution.
I first noticed it on a project we upgraded from 2010. I have since goofed around with a project that was created in 2011 and the same thing happens to that one as well. So it does not appear to be a problem with the upgrade process but the software for 2011 itself. The problem has been reported to Autodesk but at the rate the sometimes solve problems it could be a service pack before this is fixed so I wouldn't hold my breath. I will keep you updated though.
Have you tried creating a new view and placing the reference notes on it? I have had issues with 2010 before.
I did try one project that was started in 2011 and the key notes where working fine. I split the view into multiple dependent views and the keynotes started having the problem.
