Revit MEP Forum
Revit MEP 2011 - Changing Pipe 'type' after elements are drawn
6 REPLIES 6
dtiemeyer
1984 Views, 6 Replies
If I have draw an entire layout of piping and connected to fixtures, but accidentally drawn with the wrong style pipe (for example copper for the Sanitary system), is there a way to change the entire layout of piping?
With very simple pipe runs the 'Routing Solutions' button becomes available which can change the pipe type, but this does not work for any real layouts. Does anybody know the criteria of when the 'Routing Solutions' becomes available?
Dustin
My other CAD is a Cadillac and I like to Revit to the Max!
6 REPLIES 6
abulla
in reply to: dtiemeyer
When you select the pipe run, there should be a "Change Type" button in your ribbon menu.
dtiemeyer
in reply to: abulla
When I select the entire layout I do not see a button like that. Here is what I see.
abulla
Ah. Filter out your plumbing fixtures, that should work.
dtiemeyer
in reply to: abulla
Unfortunately they are not selected (red is the selection color), this is what I get when just pipes and fittings are selected.
abulla
I should have looked at the screenshot closer, looks like you're on Revit MEP 2011. Bad news... that feature was added in 2012.
One word - Schedules.
If you make your systems properly then you can find out which pipes types need changing. However, this method is not without flaws - like everything in Revit. Most of the time it will be okay but not always. Also you need to do the fittings.
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
