Revit MEP Forum
Revit MEP 2010 Won't Start
11 REPLIES 11
Message 1 of 12
654 Views, 11 Replies
I have installed 2010 MEP on several computers, and no problem. XP, Vista
32, and Vista 64.
I have one Vista 32 machine wher the splash screen will come up, but then it
just hangs there, and the program will not launch. I have tried an
uninstall/reinstall....same problem.
Any Ideas??
11 REPLIES 11
Message 2 of 12
Here is the Windows Vista 32 error code:
Description:
A problem caused this program to stop interacting with Windows.
Problem signature:
Problem Event Name: AppHangB1
Application Name: Revit.exe
Application Version: 2010.0.2009.317
Application Timestamp: 49c06e21
Hang Signature: ef46
Hang Type: 256
OS Version: 6.0.6000.2.0.0.256.6
Locale ID: 1033
Additional Hang Signature 1: 853984f1db2b59c5475ab5236c19f200
Additional Hang Signature 2: 8fe6
Additional Hang Signature 3: ca789dafdf94804b40c2c7921b041bba
Additional Hang Signature 4: ef46
Additional Hang Signature 5: 853984f1db2b59c5475ab5236c19f200
Additional Hang Signature 6: 8fe6
Additional Hang Signature 7: ca789dafdf94804b40c2c7921b041bba
Message 3 of 12
Try these tips:
http://teknigroup.com/tutorials/InstallAdsk2009.html
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
AIP 2008 SP3, AIP 2009-SP1 PcCillin AV
AMD 64 x2 3.0 Ghz, 8GB RAM GeForce 9800GT 512MB
XP Pro SP3, Windows XP Silver Theme
Message 4 of 12
I still haven't been able to get Revit MEP 2010 installed on Vista 32
machines. I have two that won't go. Tried installign Revei 2009 MEP first,
and it works fine, but 2010 is a no go. Locks up at the splash screen.
"Dennis Jeffrey" wrote in message
news:6179462@discussion.autodesk.com...
Try these tips:
Message 5 of 12
Hey I am having extactly the same problem you have, I have tried uninstalling it including all the folders and all the files assosiated with revit mep 2010 also deliting the registry entries and them installing it agaig but when I try to load it it just stays in the splash windows and seats there for like a minute or two before I have to close it because is not working. SOMEONE PLEASE HELP!!!!!!!!!!!!!!!!
Message 6 of 12
I never did get it to work on the one machine......let me know if you figure
something out
"alexisleo" wrote in message news:6254260@discussion.autodesk.com...
Message 7 of 12
ahawks.gmci
Are you trying to install is by the DVD or the Demo of Autodesk website? If you are still having problems try to download it & install it the other way. There might be a scratch or something on DVD that cause the problem. That is what I am guessing that is makiing something on the DVD to fully install correctly.
Message 8 of 12
I have tried it many different ways.....fron dvd and from a download.
Neither worked. Neither provided an error on install either.
"ahawks.gmci" wrote in message news:6258078@discussion.autodesk.com...
correctly.
Message 9 of 12
sammyhsmith
i just installed alias 2010 and the installation seemed to go fine.
but the application won't open. i get the error report immediately every time i try to open it.
what is going on?
should i delete everything and re-download the application?
HELP pls.
Message 10 of 12
dennis
One thing we have to do alot is reinstall from the Mircrosoft website, .NET.
Message 11 of 12
mdaugird
I have had 2010 installed on this 64 bit winXP machine and I have used it to produce one project.
Yesterday I started working with the C# VSTA macros and now I have a situation similar to what is being described here.
I launch 2010 and it just hangs with the cpu usage at about 25%
I can see that the basic UI has been drawn for Revit 2010.
2009 still works for me on this machine. I have both versions as we still have projects underconstruction that were started with 2009.
any ideas are helpful. I am repairing the .NET install of the 3.5 framework right now.
Message 12 of 12
dbratcher
I was having the same problem, I finally was able to get it working.
What I did was installed Vista SP2 then any other windows updates after that until there were no more.
Revit 2010 opened up with no problems.
Hope this helps you.
David Bratcher
Luckett&Farley
Winner, Best places
to work in Kentucky, 2009
