Revit MEP Forum
Revit MEP 2010 to 2011 Panel circuit changes- HELP!!!!!!!!!!!!
1 REPLY 1
anawinterrowd
988 Views, 1 Reply
In Revit MEP 2010 was easy to select the panel and see the circuits icon, then go there to balance or change the circuit number. Where do you find this in 2011?? I tried to select the panel, but the only thing accessible under electrical tab is panel schedules. Where did they place the circuits icon???????? How can I change the circuit number or balance the electric panel? HELp!!
Ana Paula
1 REPLY 1
dennis
in reply to: anawinterrowd
If the panel is placed, distribution system assigned and then some circuits created, then you should go directly now to the Panel Schedule.  There you can edit the Panel Schedule with all the features you are are use to seeing.  So, create your panel schedule and then re-arrange the schedule.
