Your not going to get an answer here. I have seen a few post similar to this with no responses.
Installing multiple vertical softwares in the same location can create problems with paths. Installing a more current version before a previous shouldn't be an issue. You can try and reverse the installs.
Does this error happen when you try to register/activate?
If this is a .dll file it could be a corrupt dynamic link library.
Your best bet is to call Autodesk customer support
"It's hardware that makes a machine fast. It's software that makes a fast machine slow."
