Hi
I am working on a have file in revit mep 2013.
I was linked both fire safety and hydraulic revit models.
My issue is when I see in section, the pipes are not in hidden even they are behind the duct.
Just blank behind the duct.There is no issue with pipes drawn in current file.If I link that files in a new file they are in hidden lines behind the duct.
I observed that both files mep settings in mep hidden lines. What may be the reason.
Is there any settings to display linked pipes in hidden in my file.
MEP Hidden Lines should display with elements from the linked model and current project just the same. Is the View's Discipline set to Coordination, by chance? MEP Hidden Lines only functions in Views set to one of the MEP Disciplines.
Hi Cadstrophe
No luck. It is in mechanical discipline only. May be I think this related to any system type problem.
Becoz I got the same problem for the shoe pieces, which was posted previously.you had only given the answer for the post.
But I cannot find what is the problem for this issue. I don't have permission to send project file from my office.
Is there anything missing other than discipline. Thanks in advance.
Without being able to see the actual file, I'll be able to do little more than guess...
- Under Mechanical Settings, ensure that " Draw MEP Hidden Lines" is checked.
- Under V/G Overrides » Model Categories tab, verify that the "Lines" Category is visible.
- If the above is true, verify that the Subcategory "MEP Hidden" is visible.
- Try adjusting the scale of the View; maybe it is too small to display the hidden lines.
