Hello. I am trying to create a family which transfer flow rate from in to out. Also same system name.
In this configuration two connectors have same system name. But it doesnt transfer the flow rate. I need a family that calculate all air terminal flow rates and trasfer it to other connector. But connectors should be same system name. Is it possible? Thanks for your helps.
https://www.bilgitara.com
