Revit MEP
hjoyce
Message 1 of 5 (538 Views)
revit Elbow fitting
538 Views, 4 Replies
03-20-2014 05:58 AM
I have a problem with and Pipe fitting Elbow that was created in Revit 2014.  The Family flexes correctly and is correct dimensionally but when I use it, the angle that comes off a 45 elbow is slightly off.  I made sure the connectors angle is set to the Angle parameter and the Radius is set to NomRad parameter. It the JPEG you can see the elbow angle is correct but pipe angle is not.  The elbow works correctly at 90 degrees
I believe the problems is that Revit is using the Family's Origin (intersection of the Origin Reference Planes) as the intersection point for the Pipe, and the location of your Family's Origin does not match what should be the geometric intersection point. You have a parameter called "LenA2" that is controlling the horizontal distance between the vertical Origin Reference Plane and the edge of the bend. I think you'll need to use a separate parameter here to properly calculate this distance.
Compare your Family with the standard Revit generic elbow Family. (See image below).
CADastrophe
Message 2 of 5 (480 Views)
Re: revit Elbow fitting
03-21-2014 07:44 AM in reply to: hjoyce
Can you post a sample Project file that includes this elbow?
hjoyce
Message 3 of 5 (475 Views)
03-21-2014 08:37 AM in reply to: CADastrophe
Attached is a sample project with subject elbow.  Its a long radius welded elbow with OD=Nominal Diameter.  Thanks for your time Corey.
CADastrophe
Message 4 of 5 (469 Views)
03-21-2014 09:57 AM in reply to: hjoyce
hjoyce
Message 5 of 5 (446 Views)
03-22-2014 08:51 AM in reply to: CADastrophe
Thanks, great catch.  Appreeciate your assistance. Yup all good, changed lookup table paramter from lenA2>>BendRad and then lenA2=BendRad*Tan(Ang/2)
