Revit MEP Forum
Revit Duct Tag with adjustable extension line
2 REPLIES 2
788 Views, 2 Replies
Hi all,
     I would like to add a line in a duct tag that can adjust by instance parameter. but when i load it in the project, the Length parameter is not visible in the properties. My plan is creating a workaround  to have a 3 points of a leader than the 2 point limit in revit 2014. any idea or work around? thanks in advance
regards,
Jeff S
2 REPLIES 2
CoreyDaun
Hello, and welcome to the Discussion Groups!
Unfortunately, the Instance Parameters of Tag Families cannot be accessed from the Project environment. You will have to create a separate Family Type for each specified length of line. The link below is frequently provided by Autodesk personnel here, and is set up to provide feedback directly to Autodesk. I would advise voicing your needs to them on this matter.
Autodesk Product Support
The following link is setup for you to submit feature requests, or feedback, directly to our Development group:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
in reply to: CoreyDaun
hopefully next revit version have this feature. thanks for fast reply
br,
jeff
