Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Revit dimension text rotate after given any widthfactor
2 REPLIES 2
BIMAbhi
1109 Views, 2 Replies
The dimension text will change (Rotation) when export it into pdf from Revit 2014. We have attached a snap for your easy reference.
Thanks in advance!
Thanks & Regards
BIMAbhi
2 REPLIES 2
CoreyDaun
in reply to: BIMAbhi
I am not able to reproduce this behavior. I would suggest trying to use a different PDF writer, such as CutePDF or PrimoPDF (both are free) or perhaps even exporting to DWF and then printing that to PDF (silly, I know).
The above is assuming that this is not happening when physically printed, and not displaying that way in the Print Preview.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
BIMAbhi
Thanks for your valuable feedback. Now the problem have got resolved.
We appreciate your help!
Thanks & Regards
BIMAbhi
