Revit MEP
Revit MEP
Valued Contributor
tim102289
Message 1 of 2 (1,088 Views)
Revit could not find a matching Pipe Segment in Default pipe type
1088 Views, 1 Replies
09-20-2013 05:44 AM
Every time I try to start a pipe by clicking the connector on an air handler, I get the message:
"Revit could not find a matching Pipe Segment in Default pipe type. Please check the Default pipe type's routing preferences."
The connectors have a radius set to 1" so the pipe should come out 2".  When I click the connector however it always goes to 2 1/2" so I manually have to change it to 2".  And then once I click to place the segment of pipe, I get the message.  I've checked Segments and Sizes in the Routing Preferences and there is a 2" and 2 1/2" size both listed.  Any idea why I'm getting this error?
- Tim Smith
Motz Engineering
Revit MEP/AutoCAD/Sketchup
UC Architectural Engineering c/o 2016
"There is nothing more expensive than hiring cheap engineers." - Bob Sheeran, Xavier University 01/05/2005
CADastrophe
Message 2 of 2 (1,023 Views)
Re: Revit could not find a matching Pipe Segment in Default pipe type
09-23-2013 05:36 AM in reply to: tim102289
Under Mechanical Settings » Pipe Settings » Segments and Sizes, make sure that you're looking at the sizes for the proper Pipe Segment type - make sure the value of the "Segment:" pull-down matches listed under the desired Pipe Type's Routing Preferences. Each type of Segments has it's own Size Catalog.
