Maybe I am not searching the right terms, but I am not finding anything on this topic.
When I try to window select horizontal pipes, pipe fittings and accessories, they are not selected when I try to do a window or a crossing. Vertical pipes get selected however. I have to manually select each piece separately. Has anyone seen this before or am I missing a setting somewhere? I can window Mechanical Equipment and other elements, just not pipe.
Solved by casquatch. Go to Solution.
Jason,
Sounds like this could be a view range issue. Verify that those unselectable pipes aren't in the "View Depth" of your view. By this I mean, anything in the area from the Bottom of your view range to the view depth's Level will be considered in the "View Depth".
Casey
Now that you mention it, I believe that was the issue. Wow, that was a big brain fart on my part. Thanks.
