Revit MEP Forum
Revit 2015 - Window Selection
2 REPLIES 2
BCERBimMan
391 Views, 2 Replies
Maybe I am not searching the right terms, but I am not finding anything on this topic.
When I try to window select horizontal pipes, pipe fittings and accessories, they are not selected when I try to do a window or a crossing. Vertical pipes get selected however. I have to manually select each piece separately. Has anyone seen this before or am I missing a setting somewhere? I can window Mechanical Equipment and other elements, just not pipe.
Jason Peckovitch
BIM Manager | Mechanical CAD Design | Father | Car/Tech Guy
BCER Engineering Inc - Denver, CO
2 REPLIES 2
casquatch
in reply to: BCERBimMan
Jason,
Sounds like this could be a view range issue. Verify that those unselectable pipes aren't in the "View Depth" of your view. By this I mean, anything in the area from the Bottom of your view range to the view depth's Level will be considered in the "View Depth".
Casey
BCERBimMan
in reply to: casquatch
Now that you mention it, I believe that was the issue. Wow, that was a big brain fart on my part. Thanks.
Jason Peckovitch
