Has anyone else seen that you can no longer snap/grab the top corner of the schedule title "cell" on a sheet? This makes it difficult to space your schedules a certain distance apart now.
Solved by Lance.Coffey. Go to Solution.
Are you comparing between 2015 and 2014 (I'm not seeing a difference between these versions)?
I guess it would be compared to 2013. Our schedules were previously in Revit 2013 container file, but have recently upgraded to 2014. However, the project I have been creating recently have all been 2015.
Thank you for the update, I do see a difference between 2013 and 2014/2015.
It looks like you can snap/select the corner just above the column headers instead of the title. Here is a video showing this difference:
https://screencast.autodesk.com/main/details/e2fc7a77-f22f-4eac-9763-34ecb4d0fec4
