Good afternoon.
I haven't seen this before nor did I find an answer. We are working on a project that is almost identical to a project we worked on a few years ago and a few versions ago. There are differences but not much. I took the mechanical work and copied it into the new project and it landed almost where it needed too as well. I took all the air terminals, flex duct and Low Pressure ductwork downstream of the VAV's and changed them to a phase that is after the New Construction Phase (called Phase II in our project) called Not Used. The idea here is to have these elements not visible but available later on to show again instead of deleting them and redoing them at a later date.
All of this ductwork now displays and prints as dashed linework but it is unselectable. The active Phase is Phase II. The Phase Filter is set to Previous + New and the only thing visible is Previous and new, no demo, no temporary. I have no clue why this ductwork is being displayed. Here is a screen shot.
*shrugs* I am stumped.
Thanks.
It shows up the same way in a 3D view as well so I dont think it is the beyond format.
These items have been placed on a future phase, that shouldnt even be visible in the view.
These kind of errors are not unheard of in Revit. Can you try to reproduce this in a new Project file? If so, can you purge it to make it small enough to post here? (You may have to manually delete Fitting Families from the Project Browser)
I did a purge and removed everything but the views on sheets and the file is still 56mb. I can share through dropbox or something.
I have found out why dashed ductwork was shown. The dash was actually the liner, not the duct. I guess the liner doesnt take on the same phasing properties when applied. I turned off Liner in the view and the dashed ductwork disappeared.
