Hi All,
when I connect flex duct with main duct it works fine but when I do duct sizing all flex duct disconnect from main duct. This problem happend only with TAP connection.
I work in same way with revit 2013 and never face problem. Can some one let me know are they facing same issue?
Hi ,
When I used your file and draw a new ductwork with "Rectangular Duct Radius Elbows/Shoe Takeoffs_BMA" as you mentioned all is ok.
When I run the duct calculation with only selecting the main duct it disconnect from the flex duct and delete the tap "WSP_M_RoundTakeoff-Damper Standard.
When I run the duct calculation with selecting the main duct, tap and flex all together the calculation runs properly.
I think you have to run the duct calculation after selecting all three items or all system.
Thanks for your quick reply.
I checked with whole system and it works but acutally it works just with ducts & duct fittings without selecting flex ducts in Revit 2013.
Anyways thanks
