Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Revit 2013 How to add a 2" insulation to the duct?
1 REPLY 1
omileyko
1369 Views, 1 Reply
Please advise on how to cover the duct with 2" insulation.
Thank you.
1 REPLY 1
CoreyDaun
in reply to: omileyko
It should be as simple as selecting the Duct or Duct Run (highlight a section of Duct and press 'Tab') and clicking the 'Add Insulation' tool located on the 'Modify" contextual tab. The following dialog box will prompt for thickness. See image below.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
