Revit MEP Forum
Revit 2013 How to add a 2" insulation to the duct?
1 REPLY 1
1375 Views, 1 Reply
Please advise on how to cover the duct with 2" insulation.
Thank you.
1 REPLY 1
CoreyDaun
It should be as simple as selecting the Duct or Duct Run (highlight a section of Duct and press 'Tab') and clicking the 'Add Insulation' tool located on the 'Modify" contextual tab. The following dialog box will prompt for thickness. See image below.
