Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Revit 2013 - Extracting Plumbing from MEP Revit file
1 REPLY 1
jdorenkamp
284 Views, 1 Reply
I have a 350 meg file with plumbing, HVAC, and electrical. I need only the plumbing. Is there a way to remove the electrical and HVAC while maintaining the plumbing worksets?
1 REPLY 1
CoreyDaun
in reply to: jdorenkamp
Hello, and welcome to the Discussion Groups!
If the elements are reliably placed on the correct Worksets, then the best option is probably to create a new 3D View and turn off the Worksets that you wish to retain (under Visibility/Graphics Overrides > Worksets tab) and then just delete all of the visible elements.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
