Revit MEP
Active Contributor
Pabber
Message 1 of 4 (320 Views)
Revit 2012 - Re-tagging Equipment
320 Views, 3 Replies
12-04-2013 11:29 AM
Is there a way to prevent Revit from assigning new tag values to equipment / air terminals that have been pasted into the model from the clipboard?
Thanks.
The Mark Parameter is really not good to use to identify equipment. I would highly recommend using a Shared Parameter or a Project Parameter instead. This system parameter has a special behavior and Revit will automatically assign a unique Mark value to any new elements, including those created by the Copy/Paste method.
There is some more information about the Mark Parameter in this previous thread:
http://forums.autodesk.com/t5/Revit-MEP/How-to-lock-a-prefix-on-a-mark-per-family/m-p/4311723
Product Support
Alaaeldin_Alsahli
Message 2 of 4 (310 Views)
Re: Revit 2012 - Re-tagging Equipment
12-04-2013 01:13 PM in reply to: Pabber
what do you mean by new value?
you have an equipement you did ctrl c then ctrl v and when is past you see a tag or a new value?
thanks
Alaaeldin Alsahli
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Active Contributor
Pabber
Message 3 of 4 (285 Views)
12-05-2013 05:28 AM in reply to: Pabber
As an example, the project utilizes both fan powered (TUFP) and non-powered (TU) VAV boxes. We have several instances where both type of boxes share the same mark such as TUFP-12-1 and TU-12-1.
When the contents of the model is copied into a new project, Revit will rename one of the boxes sharing the same mark number to something like TU-16.
How can I prevent Revit from doing this?
CADastrophe
Message 4 of 4 (282 Views)
12-05-2013 06:08 AM in reply to: Pabber
