Is there a way to prevent Revit from assigning new tag values to equipment / air terminals that have been pasted into the model from the clipboard?
Thanks.
Solved by CoreyDaun. Go to Solution.
what do you mean by new value?
you have an equipement you did ctrl c then ctrl v and when is past you see a tag or a new value?
thanks
As an example, the project utilizes both fan powered (TUFP) and non-powered (TU) VAV boxes. We have several instances where both type of boxes share the same mark such as TUFP-12-1 and TU-12-1.
When the contents of the model is copied into a new project, Revit will rename one of the boxes sharing the same mark number to something like TU-16.
How can I prevent Revit from doing this?
The Mark Parameter is really not good to use to identify equipment. I would highly recommend using a Shared Parameter or a Project Parameter instead. This system parameter has a special behavior and Revit will automatically assign a unique Mark value to any new elements, including those created by the Copy/Paste method.
There is some more information about the Mark Parameter in this previous thread:
http://forums.autodesk.com/t5/Revit-MEP/How-to-lock-a-prefix-on-a-mark-per-family/m-p/4311723
