Hi all,
Im having problems with 5 desktop computers running the same revit project, 3 off them are having issues when zooming in on the project ( line thickness changes and also changes the way the PDFs are being created ) while the other 2 seem perfectly fine, printing and viewing.
We have checked all the settings from graphics setting to our view templates and cant seem to work it out.
Any help pr suggestions would be great,
thanks
joe
Solved by blackploughman. Go to Solution.
Do all of these computers have identical graphics hardware? Try toggling Hardware Acceleration under Options and see if that makes a difference.
Hi Corey, thanks for the reply, all computers are running the same graphics, it seems like a setting has been altered, it looks like the ductwork has a DOUBLE line, the black line seems like it should not be there, we have toggled with the shadow settings and it does not seem to change.
The other systems have not got this double line....
found it, this soultion fixed the problem...it was a windows update that casued it.
thanks 🙂
