Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
revit 2012 crash
2 REPLIES 2
alatier
432 Views, 2 Replies
revit 2012 crash
I have had problems with Revit 2012 frequently crashing when manipulating sections
With the section view open, I can move the scope box with no problems, however, when I try to move the section itself, Revit often crashes. I found that closing the view, moving the section line then re-opening the view works without problem.
Has anybody else had this problem?
2 REPLIES 2
CoreyDaun
in reply to: alatier
I haven't had this problem, but try toggling "Use Hardware Acceleration" under Options > Graphics. Also, verify that your graphics card is on "the list"; >this link< might be helpful.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
arief.rahman
Please check that you have already updated all service pack and hotfixs for Revit 2012.
The Update and hotfix for revit you can find on this link below :
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9273944
Arief Rahman
