How do y'all make your revision clouds look good? Whenever I create revisions clouds in a drawing set they (a) take way too long to create because you have to manually click about a million times and (b) look like crap because each bubble size is determined by manual placement.
Does any one have a method/system that I am missing?
Does any one know if there are any plans on creating an easier version of revisions?
IMO, you should be able to just outline a portion of the drawing with lines and then have it flash to uniform rev bubbles. Does this make sense? This is how autocad is and it makes things so much easier!
Hello There,
I am assuming you are using an older version of Revit and I am 100% agree with you. I am suffering the same pain as I am on 2014.
Revision clouds are much better in Revit 2015. They are improved by below:
- you have more options to draw revision clouds and you don't have to do click 100 times to draw a simple revision cloud.
- you can easily change the scale of the revision clouds by going to view> revisions
Hope it helps.
Cheers,
Mehdi
