Revit MEP
Active Contributor
the_cad_monkey
Message 1 of 6 (619 Views)
Renaming shared parameters
619 Views, 5 Replies
12-03-2009 06:46 AM
Hello all,
I was curious if there was any way to rename a shared parameter through API? Any help will be appreciated.
Distinguished Contributor
simon.whitbread
Message 2 of 6 (619 Views)
Re: Renaming shared parameters
12-03-2009 08:37 AM in reply to: the_cad_monkey
Check out "RevitTV Shared Parameter Manager for Autodesk Revit" from Revittv.com, does exactly what you want
Active Contributor
the_cad_monkey
Message 3 of 6 (619 Views)
12-03-2009 08:55 AM in reply to: the_cad_monkey
We have the code wrote to do this, but when we try to execute the program, we get an error that says "Cannot rename the shared parameter." How did you work around this? Any help would be appreciated. I attached a copy of the error we are getting.
Active Contributor
the_cad_monkey
Message 4 of 6 (619 Views)
simon.whitbread
Message 5 of 6 (619 Views)
12-03-2009 09:00 AM in reply to: the_cad_monkey
Is your Shared Parameter File read only? If not I'd suggest contacting RevitTV directly - they are normally very responsive.
Active Contributor
the_cad_monkey
Message 6 of 6 (619 Views)
12-03-2009 09:07 AM in reply to: the_cad_monkey
Thanks Simon. I will see what they have to say. Thanks again.
Post to the Community
New Post
Need installation help?
