I have created some Mechanical equipment and add them to the Drawings
now i have small problem, some of the equipment i dont want to include them in the schedule
how can i remove certain equipment ?
regards
Solved by CoreyDaun. Go to Solution.
You can exclude certain elements by employing Filters. Under the Schedule's Properties, go to the Filters tab. Here, you can create logical conditions to exclude the undesired information. You can use a number of possible methods to accomplish this, such as: Filtered by: "Family Name", does not contain "[unwanted text]". I would be able to give you some more specific information if you can provide a little more detail.
CADasthrope, I thought it would be as easy as you describe. However I'm encountering a frustrating situation.
I have a wall schedule from which I need to exclude all CURTAIN walls. I thought same as you: just filter out any family or type containig the name "curtain". Well it turns out that the filtering options DO NOT show "Type" nor "Family name or type".
I had to go to EACH one of my curtain wall types to:
I would like to read your opinion on this.
Thanks in advance
Yeah, the inability to filter schedules by family or type is infuriating. however, you don't have to leave the schedule to make that change - just add "type comments" or "type mark" to your schedule, add the value you want to filter by right there in the schedule, then create the filter. Or find some other characteristic unique to curtain wall assemblies that's already in your schedule and use that as your filter logic.
