Revit MEP Forum
Removing items from Schedule
5 REPLIES 5
chunky2k
12120 Views, 5 Replies
I have created some Mechanical equipment and add them to the Drawings
now i have small problem, some of the equipment i dont want to include them in the schedule
how can i remove certain equipment ?
regards
Variable Integrated Package L.L.C
Abu Dhabi - United Arab Emirates
5 REPLIES 5
CoreyDaun
in reply to: chunky2k
You can exclude certain elements by employing Filters. Under the Schedule's Properties, go to the Filters tab. Here, you can create logical conditions to exclude the undesired information. You can use a number of possible methods to accomplish this, such as: Filtered by: "Family Name", does not contain "[unwanted text]". I would be able to give you some more specific information if you can provide a little more detail.
chunky2k
in reply to: CoreyDaun
Thanks a million
it worked like a charm !!
Eduardo2012
CADasthrope, I thought it would be as easy as you describe. However I'm encountering a frustrating situation.
I have a wall schedule from which I need to exclude all CURTAIN walls. I thought same as you: just filter out any family or type containig the name "curtain". Well it turns out that the filtering options DO NOT show "Type" nor "Family name or type".
I  had to go to EACH one of my curtain wall types to:
  1. Enter"Curtain wall" text in the "TYPE COMMENTS" field (not very revit-ish, having to do this manually for each type)
  2. Go back to the schedule and add the TYPE COMMENTS field
  3. Finally filter out all fields containing the "curtain wall" text in the Type Comments field.
I would like to read your opinion on this.
Thanks in advance
bsammis
in reply to: Eduardo2012
Yeah, the inability to filter schedules by family or type is infuriating.  however, you don't have to leave the schedule to make that change - just add "type comments" or "type mark" to your schedule, add the value you want to filter by right there in the schedule, then create the filter.  Or find some other characteristic unique to curtain wall assemblies that's already in your schedule and use that as your filter logic.
Eduardo2012
Right from the schedule!!! Great tip bsammis!!
