I am very new to REVIT and I added an app that is not compatible with my version. For the life of me I can not figure out how to remove it.
Any help would be appreciated.
From what I understand, it would be sufficient to just delete or remove the following for Revit not to see the app:
C:\ProgramData\Autodesk\Revit\Addins\
Navigate here and then select the year of Revit you are using. You should see a addin file with the name of the app. Remove it here and it will not show up in Revit. I would suggest just placing it somewhere else, maybe in a folder on your desktop so you dont delete it.
Next thing, open the addin file in Notepad (its just a text file), and look for the line that is enclosed in <Assembly> (.dll file location) </Assembly>. This shows where the .dll file is located. If you navigate there, it will take you to where the meat of the app is located. You could just put the add in file within that folder structure and it should take care of your problem.
Good luck!
