Revit MEP
Revit MEP
0 Kudos
Post 1 of 7
Region not printing correctly since Update Release 2 - Revit 2014
293 Views, 6 Replies
12-01-2013 01:18 PM
Hi there, I have a region on a Generic Annotation symbol loaded into a family that is'nt displaying properly when printed, even though looks good on the preview.
Or have I made an error when creating the Family.
(attached is a screenshot of the pdf & families used)
I have updated the software drivers for the printer & pdf995.
This has only occured since installing the recent Update Release 2, and all other seeting have not been altered has anyone else had a similar issue ?
i realised that is not with any regions, i think is more when it is a circle region.
Product Support
58 Kudos
Post 2 of 7
Re: Region not printing correctly since Update Release 2 - Revit 2014
12-02-2013 05:28 AM in reply to: alijax1972
when the print windows open go to setup (right-bottom) then on the print setup page select raster processing and it should fix the problem
see attachement for a better visualize the solution
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Alaaeldin Alsahli
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
0 Kudos
Post 3 of 7
12-02-2013 02:15 PM in reply to: Alaaeldin_Alsahli
Thanks for your reply - but we changed from printing in Vector mode to Raster mode in a bid to prevent 'blocky' curved lines (see attached).
Our symbol has only started looking like the original screengrab since we installed  the update last week - when I originally posted this to @Autodeskhelp.
Product Support
58 Kudos
Post 4 of 7
12-03-2013 10:30 AM in reply to: alijax1972
the only solution that i found is to edit your family and divide you filled region into several segements, i modified your family and it does look good now when comes to printing.
the problem is nested family with a circle filled area.
i have unistalled revit 2014 and then reinstall it with update1 and i still see the problem, i see it in 2013 also
i downgraded .net 4.5 to .net 4.0 and still no solution so i guess you need to play round your family, look at how i edited your nested family
Alaaeldin Alsahli
Product Support
58 Kudos
Post 5 of 7
12-03-2013 10:36 AM in reply to: alijax1972
here is a link for you if you want to put your feedback about this problem
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Alaaeldin Alsahli
0 Kudos
Post 6 of 7
12-03-2013 02:31 PM in reply to: Alaaeldin_Alsahli
Thanks for your solution, this is the only instance this occurs - so maybe in future if there are any regions on a nested family these will be broken up to prevent this.
Product Support
58 Kudos
Post 7 of 7
12-04-2013 04:17 AM in reply to: alijax1972
Alaaeldin Alsahli
