Ok so on some things like pipes and ducts there is a parameter called reference level. This parameter seems to be dynamically populated with the levels in each revit project. If you select a new level from a drop down, the item will jump to that level. My question is this: Is this parameter something that you can incorporate into a family so that you can select a specific point in a family and say, "this plane right here needs to align to a selected level via the reference level parameter"? Thanks!
