Hi!
I generally use "pipe sizing" at all my projects but i need help on tees. i don't want to use in any of my projects reducing tee(revit automatically places), i want reducer before/after the tee. how can i fix it ?
in pictures:
i don't want to use this connection:
i want to use this connection:
In your "pipe type" family you probably have a reducing tee defined. If you replace this with a non reducing tee it should use a transition instead of reducing tee. Also note that you should also replace existing reducing tees inside your project with non-reducing tees.
Louis
Please mention Revit version, especially when uploading Revit files.
