Hi.. I am working in Revit Mep... For our test project purpose i used project file of the revit defualt system template and i have modeled a basic house with wall, floor and ceiling. And then i have placed the air terminal diffusers and VAV box and drawn the duct system. After that when i changed from wire frame view to realistic view, still the wall & floor remains Wire frame but only the duct system have changed to realistic.. Can any one tell how could i change the setting .. so that i can see everything in realistic View...Please...
Solved by CoreyDaun. Go to Solution.
The solution is to change the View's Discipline to Coordination. The Discipline of a View affects the appearance of many elements, for instance, Walls, Windows, and other "out-of-discipline" elements are automatically set to half-tone and made transparent in a Mechanical or Electrical View.
